Jan 20, 2023 #1 Raidrp Mechanical Jan 12, 2023 4 0 0 CA Hello, Any experienced PV Engineer can explain what helps them decide if they should follow Div 1 for a particular analysis or if they require a Div 2 design by analysis instead. Thank you
Jan 20, 2023 #2 pmover Mechanical Sep 7, 2001 1,500 0 36 US um, well read the introduction in both Div. you shall find your answer. or an internet search may reveal your answer. Upvote 0 Downvote
Jan 20, 2023 #3 JStephen Mechanical Aug 25, 2004 8,602 0 36 US A big part is going to be which stamps are available, and the familiarity of the designers with both divisions. Upvote 0 Downvote
Jan 21, 2023 #4 XL83NL Mechanical Mar 3, 2011 3,043 0 36 NL I’d say jurisdictional requirements rather than available stamps. And design pressure. Read U-1. Huub - You never get what you expect, you only get what you inspect. Upvote 0 Downvote
