Big H -
Sounds like your client has the same specifier as one of our big box boys (the home improvement store that's not orange in color). Their spec says that contractor shall compact mix until 96% of Rice is achieved. If contractor does this, he/she has already killed all the voids that normally would consolidate over the pavement life cycle. Kind of hard not to expect some shoving, rutting, etc. if one tried to get 96% of Rice. As far as flushing of the binder, if such a high spec is required, specifier has to know that if you compact it so hard that binder 'leaks out', something has to be wrong. I'm sure you've already told him/her this, but the pavement can expect to become rutted very soon, particularly if any heavy truck loads are applied. Soon after the rutting, I'll bet it starts to slide and pop open, thus causing shrinkage cracks followed by the evil POTHOLE (run away!!!).
Although my call name is dirtdoctor, my first love is the hot black stuff. Scraping of fines at surface - sounds like contractor has fined up mix a tad or else the rubber tire roller is not hot enough to keep from picking up the fines in the mix.
The glory days of pavement will arrive in the US soon, as Stone Mastic (or Matrix) Asphalt will become a reality. The Europeans (particularly Germany) have been using it for years, with much success. After Georgia DOT bit the bullet and put it down on I-85 (perhaps the one stretch of pavement in the US to see the harshest conditions - heat, heavy truck loads, along with freeze-thaw cycles) around Hotlanta, the pavement guys around here could be seen smiling from ear to ear. The stuff is great, but be prepared to spend some cabbage to buy it.
