We have this existing driveway that a has swale and would like to cover the swale with a built up ramp (hump) to re-direct surface water flow (see attached sketch). I have two questions that I am not so sure about. 1. In order to build the ramp, should I remove the existing asphalt top and expose the soil foundation and build it up with basecourse up to my required elevation and cap it with asphalt or should I leave the existing asphalt and cover it with the basecourse and buid it to my required elevation top with ashphalt. 2. I am concern about the ramp location is very close to the public road. As you noticed on the sketch, as soon as a vehicle gets off the public road, the ramp in the driveway immediately is encountered. I have not seen any standard how far should a ramp (hump) be from the road.
