Assembly cae
hiwiansys
AU
One of my part instances is at an angle of 52°.Before applying any constraint like translation,I need to first turn this part instance to 52° in other direction,saying I dont want this instance to be at any angle.Since I could not turn it using rotate option,I translated that instance such that it is positioned inside another instance B in which a cut is made which has the shape of the instance which is at an angle of 52°.
kindly suggest any hints in solving the above problem
Thank you in advance
Anjali
there is more than one way to do it depends on the shape of the part. may help you a need more if you can paste the picture here.
