BOPdesigner
We have a couple of users on the same project with their NX 5.0.4 data on a network folder. User 1 opens the top level assembly and starts working with it while User 2, who owns a subassembly of the top level assembly, makes a change to that subassembly and saves it. What are the different options for User 1 to have the change to the subassembly reflected in his session? I figured if he closed the subassembly and then reopened it from the assembly tree it would work. But the old data must have remained in the session or something. If he makes that subassembly the displayed part, and then hit the X in the window to close it, and then reopens it from assembly tree it works. Seems like there are probably some better ways but we can't find anything in customer defaults for assemblies etc. Is this behavior similar when you are using Teamcenter? There is some way for User 1 to be notified that some component(s) in the top level assembly have change, yes?
