milancz
- May 27, 2010
- 12
I worked an assembly which contains bearings.These were got as "igs" form and from it I made NX part.The parts (bearings) were added into the assembly.
Then I used "ASSEMBLY CUT" to do a cut through the construction.
After I did it some elements weren´t hidden.
Please, see the attached picture.
The pins and screws I was able to hide them by means of "ASSEMBLY NAVIGATOR".But elements of bearing weren?t possible to hide without being hidden whole bearing as well as in the cut.
Please, do you have any idea how to make "ASSEMBLY CUT" and all parts behind the cut were away?
Thanks a lot.
Thanks a lot.
