AdvantageDesign
Automotive
I have an assembly which contains 100+ parts. This assembly was modified and some components have been removed. The deleted parts remain in the directory. Is there a way to remove all of these deleted parts from the directory automatically? From what I have read, you can use the ugpc command to copy the assembly to a new directory. The instructions for this command aren't very clear. My goal is to have a directory that contains only the assembly file and the current piece parts. Thanks.
