Hi, I'm wondering if I can get some input on assembly configuration mating best practices.
My process generally goes like this: say I have an assembly with 20 individual parts. All parts are properly mated, but then I decide to change one part completely. I open the part and create a new configuration. If I decide to change the entire shape/design of the part, then I will usually suppress the unnecessary sketches/features from the default part and start with a new sketch. When finished I create a new configuration in the assembly. When I re-configure the part in that assembly, I get a bunch of mate errors, because the original faces/mated features no longer exist. I then suppress those faulty mates in the new configuration, and create new mates.
My questions:
1) If a new version of a part is very different from an older one, is it generally better to just completely create a new part file, or is my configuration method of suppressing/copying/adding new sketches and manipulating features reasonable and more common practice?
2) Is my method of suppressing the faulty mates and adding new ones for a newly configured part good practice? And if so, do you organize those separate mates in any way, for example by putting them in separate folders? In the past I would try to correct those faulty mates by re-mating the new faces, but doing this messes up the mate in the previous configuration, correct?
I've noticed in the past that I've had seemly random mate issues pop up, where in certain configurations suddenly things wouldn't be mated properly and I wasn't sure why, so I'm trying to see if my methods are correct. Thanks for any input!!
My questions:
