Assembly drawings with instances
plectrum1
1
0
0
Is there a clean way to create assembly drawings with repeat regions, when the assemblies have instances with different componants? Just to be clear, both the assemblies and componants have instances.
The simple answer is yes. Can you be more specific to give me an idea of what you would like to achieve.
I suspect that you may be attempting the 2d repeat region to cover all assys and part instances. This doesn't really work. You will probably need to spend a fair bit of time creating a lot of simple repeat regions and filtering them. It's a bity of a pain in the butt, it does work though.
If you want to elaborate I will try to help you.
