gobigracing
Ok I trying to design and model a big project in solid works. To start with I know a few things.
Where and how it will mount to an existing place on the truck. And where the wheels will touch. I need to design everything in between. I figured I should do this is Assembly mode so that everything has relations with each other so if i change like the length or height it will change to middle components by itself.
Basically what I wanted to do is built the front and throw down so basic wheel and then build in between. Is this the way I should be doing this. Or is there a better way. Can you add Assembly relations later. Note: I don't mean mates and mean changing the part.
Also if this is the way to do this then any tips or tutorials. If not the how should I be doing this.
