association error with design table
yusf
58
Hi all i am currently using design table inside catia..i had used before without any error but now some errrors i am getting such as while i am associating corresponding column with catia parameter the correspoing dimension suddenly changes ..for example while it is 2 in it chages to 74.84.. i checked the options but couldnt find solution..can anyone help me
In the parameter column include the units.
Partnumber blocksize_X(in) blocksize_Y(in)
If you are defining length use (in) (mm)...
Angles - deg
Derek
