ASTM A237 Forgings (WHO HAS IT!!)
CraneEng87
21
I need to find the material properties for a forging that was made to the ASTM A237 standard. I can't find a copy of it anywhere. Does anyone have a copy I could see?
Thank you.
Google tells me that
ASTM A668/A668M-23
1.6 Appendix X1 lists the current classes corresponding to the various classes of Specifications A235, A237, and A243, which have been superseded by this specification.
Maybe start there
If you need to original, I had a look at my organization's subscriptions, and it does look like you can buy the original via them
IHSMarkit / Accuris.
Andrew O'Neill
Specialist Mechanical Engineer
Australia
Thanks Andrew,
I've requested a few quotes to order the standard however none of the suppliers say they have it.
Shortly after I posted someone did point out the appendix in A668. That should be good enough for what I need. Thanks for the help.
