Dear All,
I need help
we performed a butt weld ( full penetration ) qualification with the following characteristics:
ASTM A350-LF2 to ASTM A333 GR.6
Thickness of pipe 5,54 [mm]
Diameter of Test Coupon 60,30 [mm]( 2 inc )
Welding Process(es) GTAW
Poition 6G
Amps. 100 to 130
Volts 15 to 16
Max. Heat input (J/mm) 2635
MIN. Heat input (J/mm) 1742
Wire SFA Specification ER 70S-3 ( size 2.4mm)
Preheat Temperature (MIN.) [°C] 20
Interpass Temperature (MAX.) [°C] 230
NO PWHT
as per object I obtained high hardnesses in the HAZ ( 270 - 283 HV ) on ASTM A333 GR.6 SIDE, the basic material is in accordance with NACE (<22HRC )
Do you have any suggestions for lowering the hardness? example :
Wire SFA Specification, higher preheats,ex...
I Didn't PHWT in production.
Thanks to anyone who helps me.
I need help
Poition 6G
Amps. 100 to 130
Volts 15 to 16
NO PWHT
