AbbyNormal
- Nov 17, 2003
- 780
Have a wood truss attic over a nursing home, 24" o/c truss spacing
Looking at 15x 8 spacing option with 7 psi minimum pressure available at the head.
2002 13 handbook has an asterix stating the smallest dimension is measure perpendicular to the pitch. So it is somewhat confusing, is this 8 foot up along the pitch or 15 foot up along the pitch.
Second question, can you use a quick response 7/16 head k=4.2 with the 7 psi pressure available, the piping would be a galvanized main with blazemaster branches. A year round cooling environment no freeze concerns so wet system up there.
It would sure cut down the water demand.
Otherwise, why even call it light hazard, call it ordinary II and look for a 0.2 gpm/sq ft density.
Take the "V" out of HVAC and you are left with a HAC(k) job.
