Attribute TYPE: List & epxression
sundeep198
53
Hello all,
I am new to using expressions, but i am trying to figure out few things using eng-tips
I am stuck at attribute type: List
I am not able to see LIST in Type drop dowm menu.
Also If i want assign, new expression, eg
Part - Male
how can i do so.
regards,
Sundeep
UG Nx 7.5.032
Hi Sundeep,
If you open the expressions-Editor in NX you will be able to create a new Expression. First you have to define the typ (Number, Boolean, String, Integer, Point, Vevtor and List). But the last - "List" is only available since NX8 - you are using NX7.5! So you have to Upgrade first, then you could use expressions with the "List"-Type.
Best Regards,
Michael
NX ...
