attributus in title block
Lars1978
327
Hi All,
I'm use the master model like solution for making drawings of assemblies. For making drawings mono parts I use the stand alone approach. (model an draft are in the same file).
Before using NX 12 i could use the same sheet templates for making drawings of assemblies and mono parts.
The attributes NXmaterial and comments (custom property)out of the model file where linked to fields in the titleblock.
Now when using NX 12 these attributes don't work anymore?
Does somebody have an idea?
Lars
Lars
NX12.0.1.7 native
Solid Edge ST10
Inventor
 https://files.engineering.com/getfile.aspx?folder=b18e340a-a62f-429f-8272-09146cf9d071&file=Capture.PNG
Michael,
I've deleted these material out of the file. The info box does not popup anymore thnx.
Still I can't make a drawing first and secondly add a material to the model.
When adding material afterwards and adding a second draft the material is filled in like it should....
Any suggestions?
Lars
Lars
NX12.0.1.7 native
Solid Edge ST10
Inventor
Do You have Material attribute set correctly? Maybe add "-" instead of "". Try populate title block by pressing "enter". I have similar problem, but on second and more sheet. I have to click enter on each field in title block, so the proper values are showing up.
When You assign material, what attributes show up? Since NX 11 they changed something in customer default.
With best regards
Michael
