Hi All,
I have a question on interpretation of NACE MR0175 in regard to compliance of Austenitic Stainless Steel (e.g. 304 / 316).
Table A.6 in Part 3 indicates that this type of material is acceptable as long as the hardness is not greater than 22HRc, it is solution annealed and is free from cold work intended to enhance mechanical properties.
It is the last two here that concern me, not the max hardness.
I see a lot of material certificates claiming that the material meets NACE MR0175, but commonly the yield strength is up on what i would expect from a material that has been solution annealed and the material has been cold drawn as a final process. How can that be shown to comply with the statement in Table A.6?
Cold drawing at the end of the processing is designed for dimensional tolerance but there will be an increase in properties that cannot be specified as 'incidental'.
Regards.
Regards.
