SpeedOnIce
Specifier/Regulator
- Jan 21, 2008
- 9
Hi I have a question: I have a (316) austinetic stainless steel pipe that I am looking to harden not sure how to go about this process.
I was thinking induction? Or: EndurAlloy a boronizing process. (
The pipe is meant to go on the bottom of a sled that rides on ice aprox. 120-130km/hr. The idea is that the harder the steel the less heat transfer between the ice and steel which should translate into faster speeds.
I have tried cryogenic treating it has resulted in a nicer polish smoother finsh but thats about it.
I have thought about coating but the steel can not change color (grey) and I have yet to find a coating or method that would not negatively effect the steels coefficent of friction value. I have had some tests done and the pipe already posesses a low RA value so smoothnes is not an issue but hardness is.
Any help would be apreciated. The more info the better.
