AUTO CAD
Chemical
Jul 13, 2020
107
How can I convert multiple dwg files to pdf in windows 10. actually I can convert but the problem is dwg convert to pdf with coloured line and and text. I can not do monochorome multiple file convert.
Appreciate for respond.
With Bricscad, it's in the plot options when you print and in the plotter styles you select.
I thought that's what his problem was and directed him to the plot/print manager.
IIRC, there is a Batch Plot function in ACAD. You do have to set your plot style to use B&W and I think you can plot extents, but it has been a long time since I used it.
_____________________________________
I have been called "A storehouse of worthless information" many times.
Have you tried the publish command ?
