Hi, I work with a project of using diesel to run a pig through a pipeline offshore in the northern sea. I know the auto-ignition temperature of the diesel we want to use is 450 deg C, . It is a possibility that the pressure in this pipeline will increase to a 100 barg. Will this change the auto ignition temperature by the change of pressure??
Thank you
Ann Elisabeth
Thank you
Ann Elisabeth
