AutoCAD 2008 Plot to File
BrianL
8
I switched to 2008 yesterday and am encountering a problem with using the publish command to plot-to-file. In previous versions of AutoCAD ('06 and '07) when I publish to file, a seperate file would be created for each file that I am publishing (if I published 6 files, 6 plot files would be created). With 2008, all files that I am publishing are being saved into one file (if I publish 6 files, one plot file is created with 6 sheets). I have searched the help menu and the plot and publish options for a setting to create a single file for each file being published, but to no avail. Has anybody else encountered this problem, or have any idea how to remedy it?
