Ive been using a trial version of Autocad 2009. Wondering what other users think of it particularly the ribbon ? I must say I dont find it all that worthwhile ! Any comments would be appreciated greatly !
it has some very slight improvments over 2008 - but a few bugs too, like if you change anything in the: options/open & save/Object ARX applications settings, it suddenly doesnt recognise commands like matchproperies, view, mtext, justifytext, revcloud etc.. not good!
It would seem that the above mentioned bugs are deliberate by acad - demandload system variable disables certain commands, so your best leaving it on.
Now that i've finally solved that mystery, 2009 does offer a few nice touches that 2008 doesnt have, but you need a slightly beefier pc to run it smoothly.
I've closed the Ribbon, I find no need for it. My biggest gripe is the time delay every time you execute a command. Other than that I'm pretty happy so far.
I also have 2004 and run into problems with files from newer versions of Architectural Desktop. In one case, the layer's dialog box was disabled. It did make me think my next purchase should be a BIM package, like Revit. I hope this fall when things slow down and I can play with Revit a little, I can figure out which direction to go.
