besomdave
- Jul 19, 2002
- 25
A month or so ago i enquired on here about a lisp for aligning text to an object ( I received a reply informing about the RRT lisp. It works perfectly.
Now after using it Ive been wondering if there is a similar lisp available to align one entity (line, block, Polyline etc) with another. simple example: aligning a square (polyline) with a line drawn at an angle.
I know there is the the AutoCAD 'align' command but using two source points and two destination points to get the desired affect seems over the top when the RRT lisp mentioed above can do it for text in a couple of clicks.
Does anyone know if a simple to use lisp like this is available? Any comments would be appreciated
