Autocad import into Hydrocad
AJB1262
18
I have had my license since September 2020, but this is the first time I tried to use Hydrocad to extract information from an Autocad File.
Unfortunately, I am getting an error
HydroCAD 10.10-4b s/n 09835
Error 185: Unable to open C:\Desktop\Drainage Map.dwg with AutoCAD 2021 in Hcad2020x64
Retrieving the COM class factory for component with CLSID {8B4929F8-076F-4AEC-AFEE-8928747B7AE3} failed due to the following error: 80080005 Server execution failed (Exception from HRESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILURE))
Has anyone else encountered this?
According to the error message you are using AutoCAD 2021, but HydroCAD is configured for AutoCAD 2020.
You need to rerun the HydroCAD setup program and choose your current AutoCAD version 2021.
Peter Smart
HydroCAD Software
