AutoCAD Internal Error
644Top
3
When trying to explode an object, a screen popped up with the following message:
INTERNAL ERROR: !dbblkref.cpp@3541: eNullObjectPointer
What can I do to fix this? Thanks!
644Top,
1. which ACAD-version?
1a. Any applications?
2. which objects?
3. Every *.dwg or only one?
4. Did you try the "_audit"/"_recover" command?
Lothar
ADT 2004
Lothar,
Thanks for responding. Below are my answers to your questions.
1. I am using ACAD LT 2006.
1a. Are you talking about other applications that run on top of AutoCAD? If so, then no. I am running stand-alone.
2. The object was blocked and sent to me by a customer.
3. This is the only drawing with this error.
4. I have not tried the audit/recover.
Exxit is on the right track. Try a RECOVER first and then an AUDIT and then report back.
Using AutoCAD Mechanical 2006, UGNX4, XPsp2, MSOffice 2K3
"The fear of the Lord is the beginning of wisdom"
Thanks for the tips. I was able to re-insert the block and explode it.
