Rizgar
- Aug 25, 2003
- 16
- 0
- 0
When I select an object to change one of its property (e.g. line type or layer) through the Properties Window I see on the top of the window No Selection, however I selected the object before opening the properties window and I enter new values but there is no changes after closing the window. Knowing that the PICKFIRST is set to 1 also.
I'll be thankfull if any one can help to solve this problem.
