Autocad to Excell or Access
draftingrus
4
Hello there
I'm trying to get drawing data extracted into spreadsheet or database form. I have using copy and paste with the "LIST" command, but that requires too much manipulation to get in to a format I can use
The ultimate goal is to find an easiy way to go from Drawing to CNC format; in this case a lathe program. the lathe in question does not recognize the G70 series, so all of the cuts have to be programmed.
So - AutoCad Drawing to Excell or Access format as painless as possible
Draftingrus
I was thinking of constructing toolpaths as polylines, and writing those to a DXF file, then massaging that into a G-code file... but somewhere you need to convert Y dimensions in AutoCAD into diameters as X coordinates in the G-codes. X coordinates in AutoCAD would convert directly to Z dimensions in G code space.
Have you tried any of the cheap/ freeware/ shareware CAD to CNC converters?
Mike Halloran
Pembroke Pines, FL, USA
The problem of converting y values into xnx x values (and doubled for diameters rather than radius is a snap in excell or access..... getting the information into a format that works easily ..... seems to be the rub.
I haven't tried the converters or AutoCNC - guess I need to continue the quest
Hi Guys,
You might try these guys somewhere in the AutoCAD/Software section of the forums they might be able to help: CNCZone
HTH
Todd
If you save the toolpaths in a DXF file, it should be possible to extract the core of that (the coordinates) and convert them to a .csv file with AWK or another scripting language.
Mike Halloran
Thanks. I better write that down in case I need it.
Mike Halloran
