AutoGEM Meshing Error with Import Geometry
e.carter
Industrial
Jun 28, 2017
1
Good day to all who are reading. I am attempting to run a fairly straightforward static loading analysis in Creo Simulate on imported geometry of an engine component. When meshing this geometry, I am warned in the diagnostic window that problems were encountered in preprocessing the features for the highlighted surface. I have tried several of the import geometry healing tools to attempt to clear this error with no results. What can be done to find the issue that Creo has with this geometry, and what can be done to repair it so meshing can take place? Thank you all for your time, have a great day.
Did the part solidify when importing? I suspect not since you said you are trying to heal the geometry.
Here is a link to a YouTube video on using import data doctor. There are several tips on importing which can help prevent the problem to begin with and then there are tips on fixing problems.
