Does anyone know of a relief valve that has the ability to drain the portion of pipe above the check valve?
I have a client who wishes to do this. His idea is when the check valve closes, a smaller separate valve will open (automatically) and release the water contained in the pipeline above. An AV release is already placed in the system.
I spec'd a 2" bronze ball valve on a tee above the check valve that would enable manual draining of the line. My client wishes to this automatically, but i can't see how an automatic relief valve can distinguish between a line flowing under pressure and a line containing a static volume of water.
Brian
Brian
