Automatic Initial Sketch Orientation 2
BrittToolEngineer
Aerospace
Aug 4, 2016
239
Greetings:
When entering a sketch, either new by clicking on a plane you wish to sketch on, or by clicking an existing sketch to edit, almost always, the sketch flips 180° (re-orientates). Is there a way to change how the sketch positions when entering into it?
Brent
the mechanism when creating a sketch works like this :
When you select a face to for the sketch, the normal of that face will become the + Zc of the sketch.( the face normals of a healthy solid is always out from the volume, if invards, the solid is corrupted.)
you will, when or if, the sketch re-orients look down the Zc . ( Zc+ towards you.)
on that solid, the linear edge which is most horizontal and lowest on your screen will be the +Xc of the sketch coordinate system. You can try this by rotating a simple solid slightly to see which edge will be the Reference direction ( + Xc)
When you select a datumplane , that datumplane has a positive normal side and a negative normal side, that vector will show as soon as you have selected it. The positive normal will become the sketch +Zc unless you flip the vector by either double click the arrowhead , or in the menu "reverse".
Also the reference direction can be flipped.
When the placement plane and reference direction ( and if you like the sketch origin) have been defined, NX will rotate the view such that +Xc is to the right and +Zc is towards the user. ( +Yc is then vertical up.)
If you experience that the sketch flips 180 when edited, it is because it is defined 180 flipped.
Tomas
Tomas,
Thanks a bunch for this explanation. It is all clear now.
Thanks again,
Brent
Hi Tomas
In this case.
How to repair the solid, if possible?
Thank you.
Other question a bit out of toppic.
The revese button in various menu's (sketch, constrains, etc). Can I use a shortkey for this button?
(I liked it in Solid Edge a lot)
Lars
NX12.0.2.9 native
Solid Edge ST10
Inventor
The question on how to repair an inverted solid,
I have never seen one which was created by NX itself but i have seen a few which was imported from other systems.
thereby the feature history doesn't exist and one can be more brutal in the repair.
(use Split body, extract faces , reverse normal, remove parameters, delete the original body etc.)
I have repaired a few by extracting the faces and re-sewn these into a solid body.
I have used Export - Heal geometry but it seems never on these solids have "realized" that the solid is inverted.
I have not seen an option for a hotkey on the reverse normal, that would have been nice to have.
Tomas
Hi Tomas and thank you.
Yes I tried heal and sew.
But extract faces is new for me.
