Automatic oil skimming/pumping system from O/W
3
O/WS is a Highland Tank HTC 2000.
We would like to install an automatic oil skimming/pumping system that will remove oil accumulated in the tank automatically. If we can't come up with a way to automate oil pumping, we should be able to come up with a method signal an alarm when oil level is full.
Thanks!
Quick answer that might not work as there is no indication how your system/tank might look like:
Oil/interphase detector with a 4-20mA output
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying ” Damn that was fun!” - Unknown>>
Do you have a free water surface or is the tank pressurized? If free, how about a floating rope from Oil Skimmers Inc.?
Steve
