wsmith22
- Nov 9, 2005
- 61
Does anyone have any background on automatically priming a centrifugal pump? We are having difficulty locating an automatic air vent that is NSF 61 certified for potable water. The available NSF 61 air vents are very large and heavy and out system is subject to vibration.
We have tested a backwards swing check valve to evacuate the air from the casing with some success, however, I have not found where this set-up has been used anywhere on the internet. Another option would be some sort of floating ball check valve but we are limited to NSF 61 certification or stainless steel materials. Maybe a ball/cone style check valve without a spring?
