Automating creation of weldment and changing colors of bodies 1
roldy
Aerospace
I'm stuck on a coding project for work. The task is to create cylinders along each segment of a line in the 3d Sketch. Each body will be colored based off of some values in a table, which I don't have right now, so I am instead trying to assign a color.
First problem is that I can't get the InsertStructuralWeldment to create the weldment. I can't see what I am doing wrong with this. I tried adapting the code from the help file.
Second problem is assigning a color to a body. I can see what the materialpropertiesvalues2 of a body are but I can't figure out how to assign a color to this body. I created an array of values for R, G, B, Ambient, Diffuse, Specularity, Shininess, Transparency, and Emission. I then tried to use swBody.MaterialPropertyValues = materialProp, where materialProp is my array of property values. I did a graphics redraw and the body color didn't change.
In the zip file, I included the Excel table from which the macro reads the starting point of the first line segment and then creates successive lines based off the angle and the length in each row of the table. I've also included the custom weldment profile I will be using which the macro calls for. The reason why I'm using a weldment to create these solids is because it allows me to create all the solids in one pass instead of having to create a plane on each endpoint of a line segment and then extruded my profile up to the next endpoint.
To run, extract the "testing" folder to C: and open up the empty "test.SLDPRT" file. Make sure that Excel is not open when running the macro.
I'm using SolidWorks 2021 SP3.
 https://files.engineering.com/getfile.aspx?folder=2f66c2b6-7cbf-43d5-a962-b72b20972218&file=testing.zip
Try this:
Code:
Option Explicit
Sub main()
    Dim swApp As SldWorks.SldWorks
    Dim swModel As SldWorks.ModelDoc2
    Dim swSketch As SldWorks.Sketch
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    Set swSketch = CreateSketch(swModel)
    CreateWeldment swModel, swSketch
    ApplyColor swModel
End Sub
Function CreateSketch(swModel As SldWorks.ModelDoc2) As SldWorks.Sketch
    Dim xlApp As Excel.Application
    Dim xlWB As Excel.Workbook
    Dim xlSH As Excel.Worksheet
    Dim swSketchMgr As SldWorks.SketchManager
    Dim i As Integer
    Dim x1, y1, z1, x2, y2, z2 As Double
    Dim deltaX As Double
    Dim deltaZ As Double
    Dim ToRad As Double
    ToRad = 3.14159 / 180
On Error GoTo xls
    Set xlApp = GetObject(, "Excel.Application")
xls:
    If xlApp Is Nothing Then Set xlApp = New Excel.Application
    xlApp.Visible = False
    Set xlWB = xlApp.Workbooks.Open("C:\testing\Spiles\CreateSpiles.xls")
    Set xlSH = xlWB.Worksheets(1)
    Set swSketchMgr = swModel.SketchManager
    swSketchMgr.Insert3DSketch True
    Set swSketch = swSketchMgr.ActiveSketch
    For i = 2 To xlSH.Cells(xlSH.Rows.Count, 1).End(xlUp).Row - 1
        If i = 2 Then
            x1 = xlSH.Cells(i, 6).Value
            y1 = xlSH.Cells(i, 7).Value
            z1 = xlSH.Cells(i, 8).Value
        Else
            x1 = x2
            y1 = y2
            z1 = z2
        End If
        deltaX = xlSH.Cells(i + 1, 2).Value * Sin(xlSH.Cells(i + 1, 3).Value * ToRad)
        deltaZ = xlSH.Cells(i + 1, 2).Value * Cos(xlSH.Cells(i + 1, 3).Value * ToRad)
        x2 = x1 + deltaX
        y2 = y1
        z2 = z1 + deltaZ
        swModel.CreateLine2 x1, y1, z1, x2, y2, z2
    Next
    xlApp.Visible = True
    xlWB.Close
    xlApp.Quit
    Set xlSH = Nothing
    Set xlWB = Nothing
    Set xlApp = Nothing
    Set CreateSketch = swSketch
End Function
Sub CreateWeldment(swModel As SldWorks.ModelDoc2, swSketch As SldWorks.Sketch)
    Dim swPart As SldWorks.PartDoc
    Dim swFeatMgr As SldWorks.FeatureManager
    Dim swStrucGroup As SldWorks.StructuralMemberGroup
    Dim vGroup(0) As Object
    Dim vSkSeg As Variant
    Dim vSkSegs As Variant
    Dim swSkSeg As SldWorks.SketchSegment
    Dim swFeat As SldWorks.Feature
    Dim ProfilePath As String
    Set swFeatMgr = swModel.FeatureManager
    Set swPart = swModel
    If swPart.IsWeldment = False Then swFeatMgr.InsertWeldmentFeature
    vSkSegs = swSketch.GetSketchSegments
    Set swStrucGroup = swFeatMgr.CreateStructuralMemberGroup
    swStrucGroup.Segments = vSkSegs
    swStrucGroup.ApplyCornerTreatment = True
    swStrucGroup.CornerTreatmentType = 1
    swStrucGroup.Angle = 0
    Set vGroup(0) = swStrucGroup
    ProfilePath = "C:\testing\Spiles\spileprofile.SLDLFP"
    swFeatMgr.InsertStructuralWeldment5 ProfilePath, swConnectedSegmentsOption_e.swConnectedSegments_SimpleCut, False, vGroup, Empty
End Sub
Sub ApplyColor(swModel As SldWorks.ModelDoc2)
    Dim swBody As SldWorks.Body2
    Dim vBody As Variant
    Dim vBodies As Variant
    Dim vProp2(8) As Variant
    Dim vProp As Variant
    vBodies = swModel.GetBodies2(swBodyType_e.swSolidBody, True)
    For Each vBody In vBodies
        Set swBody = vBody
        swBody.MaterialPropertyValues2 = vProp2
        vProp = swBody.MaterialPropertyValues2
        vProp(0) = 1 'Val("&H" + Mid(MyColor, 5, 2)) / 255  'red
        vProp(1) = 0 'Val("&H" + Mid(MyColor, 3, 2)) / 255  'green
        vProp(2) = 0 'Val("&H" + Mid(MyColor, 1, 2)) / 255  'blue
        vProp(3) = 1         'Ambient
        vProp(4) = 1         'Diffuse
        vProp(5) = 0.5       'Specularity
        vProp(6) = 0.3125    'Shininess
        vProp(7) = 0         'Transparency
        vProp(8) = 0         'Emission
    Next
End Sub
That worked perfectly. Thank you very much. I know my code was a bit sloppy to look at. I had intended to place the lines of code that worked together into subs once I was finished. You saved me time doing that, thank you again.
I do have one other problem that I have been trying to figure out. One of the additions I made was to turn off automatic cutlist creation and moved the bodies into a folder having the same name as the Worksheet name. If I have multiple Worksheets for multiple spiles, I'm able to go through them and create separate sketches and weldments for each sheet. When all said is done, I should have multiple folders that contain the bodies that correspond to each set of Worksheet data. When it comes to coloring, since I'm doing a swModel.GetBodies2, how do I not get the bodies that I've already colored and moved into a created folder? If I have 100 spiles each containing 100 bodies, I wouldn't want to loop through all 10,000 bodies and determine if a color has been changed or if it is already in a folder. Is there a more streamlined approach to this?
To move the bodies to a cut list folder, you can use MoveToFolder
For the color, the best way would be to apply the color to the Structural Member Feature:
Code:
    Set swFeat = swModel.Extension.GetLastFeatureAdded
    vProp = swFeat.GetMaterialPropertyValues2(swInConfigurationOpts_e.swThisConfiguration, Empty)
    swFeat.SetMaterialPropertyValues2 vProp, swInConfigurationOpts_e.swAllConfiguration, Empty
End Sub
Wouldn't applying color to the Structural Member Feature color every body of that feature the same? I will be pulling color data from my Excel file that will eventually color every body differently.
Edit: Worst case scenario is that after creating all the bodies, within the For Each vBody loop I can look at the name of the body compare the nth name to the nth-1 name and see if the spileprofile(***) changes. If it does change I create a new folder and move the selected bodies to it. As for coloring, I suppose I might be able to create an array combining all the color values of each sheet and then as a I run through each body I can pull the correct color from the array. These would be a last resort because I believe there is a better way of doing this.
If you color every bodies differently, you should create a new feature for each. Then apply the color either to the feature or its body, before looping to the next line.
I think I would still have a problem because of vBodies = swModel.GetBodies2(). I renamed the CreateSketch subroutine to CreateSpiles and put the CreateWeldment and Apply Color subroutines inside the worksheet loop. Every worksheet loop needs to run those subroutines. The GetBodies2 still finds all the bodies it found before and thus the colors I had on them before won't stay. I need a way to only collect the bodies created on the current worksheet and put only those in a folder and only color those ones. I can't figure out a search routine for this.
Edit: I've re-uploaded the zip file with the changes I made. In the ApplyColor subroutine I was experimenting with a boolean trigger to create a folder only when a new weldment is created. Two folders are created because I only have two sheets thus far but the second folder is inside the first folder and all the bodies are in the second folder. Even though the bodies show all red, they eventually will be all different colors when I pull that information from the table.
This will give each body a random color and put them in a folder
Code:
Option Explicit
Sub main()
    SetWeldmentParams swModel
    GetExcel Empty
    CreateSketch swModel
    swModel.ClearSelection2 True
End Sub
Sub CreateSketch(swModel As SldWorks.ModelDoc2)
    Dim i As Integer
    Dim ws As Integer
    Dim FeatName As String
    Dim ToRad As Double
    For ws = 1 To xlWB.Worksheets.Count
        Set xlSH = xlWB.Worksheets(ws)
            If i = 2 Then
            Else
                x1 = x2
                y1 = y2
                z1 = z2
            End If
            x2 = x1 + deltaX
            y2 = y1
            z2 = z1 + deltaZ
        Next
        swModel.BlankSketch
        FeatName = CreateWeldment(swModel, swSketch)
        ApplyColor swModel, FeatName, xlSH.Name
    Next ws
    xlWB.Close
    xlApp.Quit
    Set xlSH = Nothing
    Set xlWB = Nothing
    Set xlApp = Nothing
End Sub
Sub GetExcel(void)
On Error GoTo xls
xls:
End Sub
Function CreateWeldment(swModel As SldWorks.ModelDoc2, swSketch As SldWorks.Sketch) As String
    Set swFeat = swFeatMgr.InsertStructuralWeldment5(ProfilePath, swConnectedSegmentsOption_e.swConnectedSegments_SimpleCut, False, vGroup, Empty)
    CreateWeldment = swFeat.Name
End Function
Sub SetWeldmentParams(swModel As SldWorks.ModelDoc2)
    Dim swBodyFolder As SldWorks.BodyFolder
    Set swFeat = swModel.FirstFeature
    While Not swFeat Is Nothing
        If swFeat.GetTypeName2 = "CutListFolder" Then
            Set swBodyFolder = swFeat.GetSpecificFeature2
            swBodyFolder.SetAutomaticCutList False
            swBodyFolder.SetAutomaticUpdate False
        End If
        If swFeat.GetTypeName2 = "SolidBodyFolder" Then
        End If
        Set swFeat = swFeat.GetNextFeature
    Wend
End Sub
Sub ApplyColor(swModel As SldWorks.ModelDoc2, FeatName As String, FolderName As String)
        Set swBody = vBody
        If InStr(swBody.Name, FeatName) > 0 Then
            swBody.Select2 True, Nothing
            Randomize
            vProp(0) = Rnd 'Val("&H" + Mid(MyColor, 5, 2)) / 255  'red
            Randomize
            vProp(1) = Rnd 'Val("&H" + Mid(MyColor, 3, 2)) / 255  'green
            Randomize
            vProp(2) = Rnd 'Val("&H" + Mid(MyColor, 1, 2)) / 255  'blue
        End If
    Next
    Set swFeat = swModel.FeatureManager.InsertSubWeldFolder
    swFeat.Name = FolderName
End Sub
This is exactly what I needed. Thank you. I totally forgot that I can make a folder for a weldment and it would be in the cutlist. Last night I was coding an alternative by searching the faces of the weldment feature to get the bodies which then I could change the color and select and add them to a folder. Of course I would have to create a collection so that I could check if I already had found the same body.
