Hey everyone Im new here! I was wondering if you could help me solve a problem. I am developing a Traction Control System for my Classic Car. A 1974 mk1 Ford Escort.
The car currently has a Digital Dash and is running a CAN network for engine RPM/Wheel speeds etc.....
PICTURE OF DASH:
For the traction controller I am using a PIC18F1320 to read wheel speeds from the CAN network, calculate slip and adjust the firing sequence of the injectors accordingly.
My problem lies with actually cutting the injector pulses so the injectors do not deliver any fuel.
When I was developing the system I designed it with the assumption that the injector is permanently grounded and the Engine ECU supplies the injector with 12v when an injector is required to deliver fuel.
The Traction Control system would sit in-between the Engine ECU and the injector. When no fuel cut was required the Traction Control would simply mimic thevoutput from the Engine ECU, and when a fuel cut was required It would simply not drive the injector:
However, after reading further literature on websites and texts books; it is evident that in most cases the injector is permanently connected to 12v and the Engine ECU grounds the injector when it wishes to deliver fuel. This is where I am stuck; I am unable to come up with any satisfactory way to interrupt the signal.
After researching other TC Systems I beleive an alternate method is this one:
However from this I am unable to figure our how to reliably interupt the injector pulse one pulse at a time. Does anyone have any suggestions?
regards,
Lee
PICTURE OF DASH:
regards,
Lee
