Nutznbolts
I built 600 tons of structural weldments in Asia using AWS D1.1.
All the parts were fabricated and tested, shipped to site and installed on time. Everything fitted perfectly. The facility is ready for use.
Now the customer's welding guy is claiming that it does not comply because we did not use ASTM steels as specified in AWS D1.1 and therefore we can't use the AWS D1.1 prequalified WPS. I don't believe he has a valid argument.
The steel we used (Pipe, plate and RHS) came from Europe, Asia and Australia. There is no issue with the steel quality.
All the steel we used is equivalent in chemical composition and strength. All the steel has been accepted by the design engineer.
All the steel complies with the AWS D1.1 "Group" definitions.
My arguments are:
• AWS D1.1 is for low carbon steel (Min yield strength 690MPa and below) so, inherently, there is low risk of failure by incompatibility.
• AWS D1.1 does not exclude equivalent steels.
• All the steel has been accepted by the design engineer.
• Use of equivalent steel is not an essential variable
Anyone else been confronted with this issue? How did you resolve it?
Thanks for reading and responding.
My arguments are:
