AWS D1.6 welder qualification 1
ATSE
594
Here's a question for the D1.6 stainless welding code experts.
Joe Welder’s FCAW-G (using A5.22 filler) performance qualification shows:
- Base material = 304L [base metal group A]
- Filler = 308LT1-4 [filler metal group B with C25 gas]
If I understand Table 5.3, Table 6.5, and Table 6.11, then he can also weld on any base metal group A or B, using any matching filler metal, with either 25% C02 or 100% C02.
That is, base metal group, filler metal group, and shielding gas (-1 to -4) are not essential performance variables.
So per D1.6, Joe's qualification permits him to weld 316 plate [base metal group B] with 316LT1-1 with 100% CO2 per D1.6 and B2.1.
Is that correct?
I'm probably barking up the trees here but also under EN/ISO, shielding gas is not an essential variable for a welder's performance qualification.
I explain to my clients (but I have no idea if that's really a valid reason), that shielding gas is mentioned and has a range under the PQR and therefore the welder should always have at his disposal, the correct WPSses (that mention all of these details).
ATSE,
There are more experienced people on here with regards to AWS D1.6 so hopefully they will respond.
IMHO - you are correct.
The important thing to remember is a Welder Performance Qualification is a test of the welders ability to produce a defect free weld based on a qualified WPS (as kingnero noted).
The requirement to produce a "sound" weld (metallurgically / mechanically) is dealt with via the PQR/WPS.
Hence the difference in essential variables.
Hope that helps,
Cheers,
Shane
And always look at the WPS, in some cases things such as gas may be flagged as 'additional essential variables'.
Welder Performance Qualification is a test of the welders ability to deposit sound weld metal...ie: a defect free weld.
This is old but I don't think it was answered.
Forget about Table 5.3, it is irrelevant for performance quals. Qualification with any base metal listed in AWS D1.6 or any Group I or Group II material from AWS D1.1, qualifies you to weld any base metal permitted in D1.6 (see 6.13.5). Qualification with an F6 filler (E308LT1-4) qualifies them for all F6 wires in that welding process, which includes E316LT1-1.
