Axial compression & bending stress
sivasooriyan
10
Dear all,
Is there any chance of uniaxial load act on circular hollow section?
I have to design one circular column (document attached). I have selected the formula (attached) from aluminum design manual.
As per attached formula, I need to calculate Major principal axis and minor principal axis bending.
As Ixx & Iyy is equal in circular section, i am confused to take major and minor axis.
shall i take 0 in minor axis bending moment?
request all help me to solve this.
 https://files.engineering.com/getfile.aspx?folder=97f1e0c7-de6e-4709-8b33-735a08226c2d&file=pipe.pdf
Dear all,
 https://files.engineering.com/getfile.aspx?folder=016e5f4e-b34a-480e-a0aa-4c066b798ecc&file=Aluminium_design_manual_2010.png
yes, if you have a round section, then the moment vector aligns with the principal direction, and then there is no other moment acting, so zero.
For what it's worth, examples 4 and 15 in the back of ADM 2010 address bending and compression of pipes
ADM ???
Sorry - Aluminum Design Manual from Aluminum Association - OP had included a page from it, but I should have been clearer.
In this case , “All Roads Lead to Rome”...
- You may choose bigger moment axis major and other is minor ,
- Or you may calculate the resultant moment Mr= SQRT( M1**2 +M2**2) and assume the major axis at Mr and Mmin is zero as pointed out by rb1957 (Aerospace)..
If you put garbage in a computer nothing comes out but garbage. But this garbage, having passed through a very expensive machine, is somehow ennobled and none dare criticize it. ( ANONYMOUS )
