Hello, I created a model of a multi-storey building and I find that the results are not the expected of a traditional static analysis for the beams that are supported by columns and walls because the shortening of axial column invests efforts in the M-V diagrams.
This happens because the program apply all the loads instantly and does not consider shortening part of the structure as it is being built.
I used the construction sequence case analysis and the
results do not change much.
What should be the way to model the building so that the beams are not deformed more in supporting column?
Thank you for the help ...
