VinuCG
- Aug 25, 2021
- 5
I have a condition in my design drawing, beams having axial loads indicated. My fabricator preferred connection is bolted-bolted clip angle for beams. Web side shop bolted with STD holes and OSL field bolted with short-slotted holes. Anyone help me whether this connection will work with axial loads. Also please help me, if the connection is shear tab with short slotted holes i must use SC connection instead of bearing at axial load conditions. Please add what are the other preferred connection i can use for axial load beams and connections that should not use.
