[b]bold[/b]Spray Dryer vs. Evaporator
workingbugs
Bioengineer
Dec 3, 2010
5
I was just trying to decided which piece of equipment would be better suited for my process. I have a process of producing Succinic Acid by E. Coli fermentation and once the fermentation is complete I need to reduce the volume of my batch so I can concentrate the Succinic Acid. I first thought that an evaporator would be best to reduce the water and then I can filter out any solids and crystallize the Succinic Acid with Sulfuric Acid and continue the process but then I came across spray drying and thought this might work because later on downstream I have to decolor a solution after I dissolve the crystals and redry the Succinic Acid which most likely use a spray dryer. I know that spray driers can be finiky due to clogging so I was wondering if the spray dryer would be useful here or if the evaporator would be better suited? What is the usual industrial practice on this?
Your process sounds similar to one I worked on. It fermented bateria to produce an amino acid. After fermentation, we sent the solution to a series of decanting/washing tanks to let the cell bodies settle out.
The decanted liquid was evaporated to increase the acid concentration before crystallizing. The crystals were dried in a Bepex indirect heating dryer.
I wouldn't recommend evaporating the water before filtering out the solids. The solids could clog your system and you would waste energy heating the solids during evaporation.
