B.O.M. Question
MikeInSoCalif
Industrial
Feb 14, 2005
44
If I have an assembly that has 5 different bolt types in it, all inserted thru the toolbox via drag and drop, how do I set independant properties so they show up in the BOM automatically.
Since each bolt in my assembly is just a different config of eachother, when I go to file>properties, and set my info, it changes for all the bolts.
Thanks.
Are you setting the properties in the Custom or Configuration Specific section?
[cheers]
Making the best use of this Forum. faq559-716
How to get answers to your SW questions. faq559-1091
Helpful SW websites every user should be aware of. faq559-520
Hey, thanks for the help, telling me I did it wrong fixed it!!!
What custom properties are you creating?
Have you modified the BOM to include those properties?
[cheers]
Then why don't you describe what you did in greater detail, then maybe someone could help you further.
Your answer to CBL was lacking a lot of information, as well as your intial post.
Custom Properties and Config Specific are the ways to set up each of the parts, then in the drawing the BOM will find the data used for that Config Specific component and place it in the BOM. The key is you have to set this up @ the part level.
Scott Baugh, CSWP [pc2]
3DVision Technologies
faq731-376
faq559-716 - SW Fora Users
Make sure you do not have the same property name defined in Custom that you have in Configuration Specific.
If it is in both places - DELETE ONE! If SWx does not know which one to grab, you've got a 50-50 chance of getting the right one.
To elaborate on MElam's post. Any property in the Configuration Specific tab always overwrite what is in the Custom tab.
If you want the property to define all configurations it is best to keep it in Custom. If you have a specific property that needs to define a configuration put it in the Configuration Specific Tab.
You cannot have a property controlling both Custom and Configuration Specific.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.0
