[b]Structural Gypsum Roof Panel?[/b] 6
Einsteim
76
Does anybody have information or a source regarding what appears to be a gypsum based structural roof? I visited a building today that has this type of roofing material with wire reinforcing embedded about a 1/3 up from the bottom...it appears to be around 3" thick. They may be prefabricated roofing panels. It spans roughly 1'-9" with embedded purlins. It has some sag that is quite evident. This building is likely 100+ years old. I have attached a picture from the underside.
The contractor wants to place a RTU that will add point loads AWAY from the steel trusses and directly on the gypsum material. I am not going to allow this, but thought maybe somebody would have some information on whatever this is ans some type of allowable loading information.
It may be Gypsum fiber concrete.
Do a web search for reinforced gypsum concrete suspension system. Gypsum concrete is calcium sulfate mixed with water.
Try the gypsum association ( I contacted them about gypsum roof decks and I was e-mail a brochure from 1973 for this type of roof deck. It contains properties, load tables etc.
I also uploaded this PDF file to engineer.com (first time I've tried this, let me know if it works).
This appears to be exactly what we have, thanks so much guys.
It looks like a system that uses steel bulb tees spaced out, then a 5/8" gypsum board (or something like that) then a poured gypsum topping.
Or it could be a Tectum board system (
The gypsum topping used to have a product called Zonolite (I think) - that had asbestos in it.
Also, here is another thread that is similar to your question:
thread507-84338: Capacity of a gypsum roof
It is not Tectum or Insulrock, the two most common gypsum decks, because they are very fibrous in appearance. I agree that it is gypsum board form on bulb tees with poured gypsum topping.
