Hello everyone,
This may sound extremely silly as I’ve been banging my head against the wall and overthinking this all day…
This is a 3 part question…
1) Is A-1 table in B16.5 considered max flange hydrostatic test pressure?
And if not…
2) How does one calculate the max flange hydrostatic test pressure (per flange rating) for P1.1 materials?
3) Where do these hydrostatic test pressures originate from?
CL150=450PSI
CL300=1125PSI
CL600=2225PSI
CL1500=5575PSI
CL2500=9275PSI
This all originated from my superior telling me that max flange test pressure is 450PSI for CL150, 2225PSI for CL600 etc. yet I cannot figure out where these numbers originate from. I have also seen numerous charts where these numbers keep showing up with no explanation as to where they came from or the math to figure it out. I have even went back as far as looking into ANSI B16.5-1988 to see if the ceiling pressure matches these numbers and they do not (assuming A-1 table is max hydro test pressure)
My concern is that if A-1 is max test pressure, that the company has been over pressuring CL150 to 450PSI instead of the stated 435PSI… all other classes from question 3 are well within the A-1 table.
I should also add that piping code is B31.3.
Test pressure is always supplied by the client which is typically 428PSI CL150, 2222PSI CL600, 5558PSI CL1500, 7000PSI CL2500.
I have considered wall thickness to be a factor as well, but am more curious as to how these pressures in question 3 arise with no explanation and WT not considered.
Any help would be greatly appreciated.
And if not…
CL150=450PSI
CL300=1125PSI
CL600=2225PSI
CL1500=5575PSI
CL2500=9275PSI
