billbon
- Apr 2, 2008
- 2
When building steam piping in accordance with the B31.1 Power Piping Code I would like to know what the allowable miter, if any, could be in the middle of an aprox. 30 ft. run of 12" Sch 40 CS pipe. We have an elevation change that requires a 5 degree offset. The run of pipe would have a 5 degree angle then an aprox. 10 ft. length of pipe, another 5 degree angle then the piping continues on to make the elevation change. Will a single bevel, open root, full penetration welded mitered joint, with a 2.5 degree angle on each pipe be an acceptable and an allowable solution. Or would a 5 degree bend be more acceptable than a miter? If so , why? The opp. pressure is 75 psi. max. The system will have a lower opp. pressure of 35 psi. during the off season. I see there are formulas for design in the code book but I'm not sure how to complete these design calcs. or if they're even necessary. Please advise. Thanks billbon
