I'm trying to calculate the stress ratio per 323.2.2(b)(1) to determine the MDMT reduction in figure 323.2.2B.
per B31.3
(1) circumferential pressure stress for the condition
under consideration (based on minimum pipe wall thickness
less allowances) divided by the basic allowable stress
at the condition under consideration.
I have:
(P*(D-(2*Y)*t))/(2*t)/S
P= pressure
D= outside diameter
Y= coefficient from table 304.1.1
t = thickness with UT and corrosion removed
S = material allowable at ambient
I think it is correct, but I don't have any way of checking, AKA commercial software to compare MDMT's to and no one I work with knows. Any help would be appreciated.
per B31.3
I have:
P= pressure
D= outside diameter
