tommynugroz
Industrial
- Sep 24, 2004
- 4
Hello !
We had an unused Sulphuric Acid Cooler, a horizontal fixed tubesheet Shell & Tube type. It was used to cooling down the circulated Sulphuric Acid liquid on its Shell Side. Sea water was the coolant on its Tube Side. This cooler operation time was relatively short since it was installed on 2016 (3 years old). However, it had an increasing trend of LMTD, even with the same Q load, Sea Water and Acid flow. It meant it heat transfer performance was decreasing. During twice periodical maintenance shutdown time, we had opened its Tube Side to confirm for any clogging materials, the condition was clean. We also conducted water jet cleaning on each tube and there were no clogging tubes. When operating, the acid circulation pump's pressured discharge and motor current were still normal, same as previous.However, its LMTD was still gradually rising up. And finally, we decided to replace it with the new one. And everything was back to normal.
If the tube side was normal, then there might be something wrong on its Shell side. We suspected that some baffles position might be changing even it did not clogged the Shell Side flow, or, some Baffle Plates had been corroded and perforated, so the acid were mostly flowing passing through the baffles instead of up and down following the baffle cuts. Hence, we would like to inspect inside condition of the Shell Side and its Baffles. But we would like to avoid any damaging test.
Is there any kind of Non Destructive Test to check the baffle condition inside of a fixed tubesheet Shell & Tube Exchanger ?
