mechmania
- Dec 27, 2005
- 35
Hello All,
We have vertical Condenser designed for concurrent flow.
Vapor Inlet at top tubeside and Brine inlet top at shell side. Shell side inlet and out let nozzles are at 90 deg to each other. And the baffle cut for the 1st baffle at the inlet is parallal to nozzle inlet.
How does it make difference themal performance wise if we use the same condenser with countercurrent flow with brine inlet at the bottom of the shell.We can not change the configration of the baffels as tubes are already fixed in to the tubesheet and fabrication is completed.
Can we use the sam unit with countercurrent flow?
Any input is appreciated.
Thanks.
Thanks.
