I am looking at a unique application where I am planning on using ball bearings to transmit torque between two mating shafts. I have uploaded a picture of the general idea. (Forgive me the picture was done quickly with paint.) There is only one ball in the picture but this will be copied several times around the shaft in a circular pattern. Also, the reason for this design is to transmit torque while allowing the "beige" outer shaft to move freely along its its own axis.
My question is two fold.
1. Has anyone dealt with an application that is similar to this? Would you mind sharing your experience?
2. Would this best be considered at a spherical keyway of sorts, when measuring torque capacity?
