Ball Pen Tip 2
lukin1977
397
Does anyone know where can I buy like a big ball pen tip.
Ball diameter: 5 mm aprox
lukin1977
5 mm would be a ball bearing, wouldn't it?
TTFN
faq731-376
7ofakss
I've seen paint markers that had a ball about that size in them.
Maybe I did not explain myself good enought. I dont need a big ball pen.
I need a mechanical devise that it is similar the tip of a ball pen. But bigger
I dont even know if it exists or do I have to build it myself
lukin1977
Any small ball bearing from scrap yard can be sourced.
do you want to distribute fliud with this ?
or (like cowski posted) you just want a ball bearing in a housing ?
Quando Omni Flunkus Moritati
I think you're looking at custom. It's not clear to me that a ball-point pen tip can be arbitrarily scaled
TTFN
faq731-376
7ofakss
lukin1977,
if you had one what would it do for you?
Some of those are veined tungsten carbide. Looks like worm tracks on the surface.
Multi Metals in Louisville, KY used to make balls for dot matrix printers.
We can get them for you in carbide at about any size If you nonly
Thomas J. Walz
Carbide Processors, Inc.
Good engineering starts with a Grainger Catalog.
Those are sometimes tungsten carbide.
They are round but not smooth. The surface looks like worm tracks to hold the ink.
We can look for them or have them made in carbide.
Personally I would try anything else first.
Tom
Thomas J. Walz
There is a chance that lukin1977 may return and tell us he needs the OTHER end of the pen that goes click-click... all speculation until we get a well defined problem.
You can use the nozzle from this device. It uses a 3/16" diameter 440C stainless steel ball, which is fairly close to 5mm diameter.
What immediately springs to my mind are these. You may have to do a bit of hunting for the right size though. As others suggested, some sort of application would be useful (I know you have an application - I mean, telling us what it is).
Thank you very much to all. I was out of the office the past 2 days
I didn´t kwow how to call the "ball pen device". Now I know it is called BALL TRANFER.
The links that amerreyenke and cowski posted are excellent. That is just what I was looking for!
I need them for a machine that I am modifiying.
lukin1977
