ubagas
- Jan 8, 2013
- 4
I'm currently developing an application for mobile loyalty system.
In this application you will be able to store your discount/loyalty cards on a smart-phone.
Application works like this:
You scan your loyalty card's bar-code and save it on smart-phone.
When you are in a store you just show your loyalty card's bar-code on a smart-phone's screen for a discount.
The problem:
Not all types of bar-code scanners can scan directly from a smart-phone screen.
Bar-codes from the screen can easily be read by CCD or Camera-based scanners.
But if you use laser scanner you will find very difficulty or nearly impossible to scan a bar-code from a screen.
CCD or Camera-based scanners are quite new and expensive, so not all the stores have them.
Nearly 70% of the time you will find a laser bar-code scanner in a store.
Now talking from the business point of view it is possible to provide new scanners together with an application.
But talking about business - the stores won't be very happy with this kind of investment, since their current laser bar-code scanners
are perfectly doing their job.
My question to you:
Is there a way, to overcome this technological barrier, so the laser bar-code scanners could scan the bar-code from the smart-phone screen?
P.S.
I tried many different kind of filters: few types of anti-reflect screen protectors, matte film, tracing paper, nothing worked.
I also tried to make a bar-code not black and white, but black and red so foto-element in a scanner would get, not reflected light from a scanner, but emitted light from a screen, it didn't work either.
The problem:
My question to you:
P.S.
